No 3rd or 4th, but STRONG 1st and 2nd???
Old Jan 19, 2012 | 01:31 PM
92RS_T-Top's Avatar
Car: 92 T-Top RS Camaro
Engine: 305 .30 over Mild RV Cam
Transmission: Auto 700R4
I have a 92 RS Camaro, i bought for a project car, knowing it had some slight issues with the trans.
Issue with the trans..
The shift linkage is WAY off, and i have no idea how to adjust it, but i put the car in overdrive manually from under the car, and still no 3rd or 4th gear.
Here is where i get confused... THE trans dosnt slip... no signs of slipping as far as i can tell.
First gear, will hold STRONG, and will smoke the tires off with ease, it will even do a power brake REAL easy, so 1st dosnt slip..
2nd gear hits strong (like it has a shift kit in it) under normal accelerating.. now when hammerin down on it at WOT it hits WAY HARD, barkes the tires, and gets a little sideways... but after that... it just keeps building RPMS and never shifts....
Put it up on the stands, and checked the shifting again with no pressure on the rear tires... placed it in first gear, and let off the brake, car ideled up to 15 mph and then shifted into 2nd with ease, but never went into 3rd or 4th.. So im stumped.. First and 2nd hit so hard that I just dont see how the 3/4 clutch disks could be shot, and i dont yet want to pull the trans out before chaseing down all the little grimlins it could be..
That and i dont feel like building a 700r4 in 30* weather lol already have to build one for my daily driver (also 92 rs) so 1 less would be nice.
Thanks guys/gals hope you all can help me out here... Ken
Old Jan 19, 2012 | 02:06 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Re: No 3rd or 4th, but STRONG 1st and 2nd???
A LOT of times when the 700's go(I'm not a tranny guru, but have had this happen several times, so I'm not exactly what goes inside), but they usually start slipping horribly bad or lose 3rd and 4th.....
That equals a full rebuild
Old Jan 19, 2012 | 02:13 PM
92RS_T-Top's Avatar
I just blew up the one in my daily driver (92 rs) and its sliped for well over 5 months before it got to the point i wouldnt drive it.. and it lost 2nd gear faster then 3-4 so thats just something i was wondering about, first 2 700r4s ive ever had. These things are crazy little things... So many things that could go wrong
Old Feb 25, 2012 | 06:41 PM
Sttn89's Avatar
Car: 89 caprice
Engine: 350 650 dp on roids
Transmission: 700r
I have the same prob in my 89 caprice.but i put in a corvette servo nd upgraded the springs.is it possible that i put that servo in backwards nf it wont engage 3rd or 4th?
Old Feb 27, 2012 | 04:22 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If it shifts from 2nd and acts like it's in neutral, the 3/4 clutch pack is toast. Pretty common. Only thing left is to open it.
Old Feb 27, 2012 | 09:54 PM
92RS_T-Top's Avatar
Nope never leaves 2nd gear... and holds it strong even at wot.
Old Feb 28, 2012 | 08:22 AM
Willsmith305's Avatar
Car: 1989 Camaro RS
Engine: 305 Carb
Transmission: 700R4 Mild shift kit.
I'd say your 3rd and 4th clutch pack is burnt up. Experienced the same thing with mine and just rebuilt it.
Old Feb 28, 2012 | 04:02 PM
92RS_T-Top's Avatar
I would if pro built would send me my stuff... been a month and nothing yet.
Old Feb 28, 2012 | 10:55 PM
Car: 1989 Camaro RS
Engine: 305 Carb
I paid a guy I knew to do it. $500 for him to tear it apart replace the clutch and anything else that looked bad and throw in a mild shift kit too and he has a transmission washer too so it looks perty. Pretty good deal if ya ask me.
db057
Apr 28, 2019 07:45 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
scottmoyer
Sep 7, 2015 07:06 PM
rudolphschenker
Sep 4, 2015 02:41 AM
