700r4 swap question
700r4 swap question
hey guys my 700r4 is starting to go i found other 700r4 that is completely rebuilt with a bunch of upgrades the guy says its from a 89 camaro will it work in my 87?he wasnt sure if the speedo used the same system( i know nothing about how the speedo works but he said one kind is cable and the other is electric? or magnetic?)i just wanted to make sure the tranny will work with my car before i buy it any info would be appreciated
Car: 1986 Camaro
Engine: 350-4bbl-Edelbrock Headers
Re: 700r4 swap question
sorry no-one has responded to your post. I have a similiar question. I have a 86 Camaro 700R4. Wanted to know what other 700R4's I could use for a swap. Good luck getting an answer.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Just swap the speedo assembly over from the old trans. You'll need to swap the speedo gears anyway to keep the speedo accurate.
You can use any 700R4 from an 82-92 F body (or swap the tailshaft housings). Earlier ones (82-84) may require the original converter to be swapped over as well.
Car: 1986 Camaro
Tons of vehicles used the 700R4, most can be swapped into the F Body by swapping the tailshaft (the F Body tailshaft has the fittings for the torque arm). Stick with an F Body one if possible, preferably one of the 'sportier' models as the inards (primarily shift points) will be better. Later models have slight improvements over earlier models. Early (82-84) may have the lower spline count on the input shaft and torque converter selection may be limited. Mid 87-up models have the secondary valve body for improved shifts.
Keep in mind that the 60 degree V6 700R4 will not bolt to a V8.
The tailshaft does not need to be swapped to change speedo gears/sender, just the one bolt that holds this assembly in the tailshaft.
Car: 1986 Camaro
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Info that you may find helpful on the drive and/or driven gear sway:
http://sethirdgen.org/vss.htm
JamesC
JamesC
Iroc8t8
May 4, 2026 08:09 PM
