9 bolt maximum torque?
Old Jan 25, 2012 | 03:01 AM
shone190's Avatar
Hi guys,
does anybody know how much torque 9 bolt BW differential (from Pontiac Trans AM 5.7 GTA 1988) can handle?
I have one Viper V10 engine and want to put it in GTA, so I need to know is it's 630Nm safe for 9 bolt diff
Old Jan 25, 2012 | 08:24 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 9 bolt maximum torque?
If you drive lightly and use factory tires it might last for a while. At minimum get a strong rear diff cover.
Old Jan 26, 2012 | 05:12 AM
shone190's Avatar
Where I can buy stronger 9 bolt diff cover?
Old Jan 26, 2012 | 06:04 AM
shone190's Avatar
I just found on Hawks Third gen, they have cover and gasket for 150$
Old Jan 26, 2012 | 07:55 AM
midias's Avatar
Sounds good and a little cheaper than ebay
Old Feb 1, 2012 | 10:59 AM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
I talked to a guy that said they were using a 9 bolt in a 700HP car. I just don't know what all they had to do to the rearend to make it withstand that kind of power. I put a TA Performance support cover on mine along with the bearing cap studs.
Old Feb 1, 2012 | 05:40 PM
dprest68's Avatar
Engine: cammed LS1
There is an article on this thread on page 4 that says they can be modified to be good up to 850HP using 31 spline axels and a few other things. https://www.thirdgen.org/forums/faq-...w-about-4.html
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
angel2794
Sep 8, 2015 06:22 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
