Transmissions Mount Problems!
Old Jan 29, 2012 | 09:31 PM
Kozusnik's Avatar
Car: 1986 Sport Coupe Camaro
Engine: V6 2.8L vin S 173ci - MFI GAS
Transmission: 5 Speed Manual
I have a 1986 2.8L 5 Speed manual transmissions and the dumb rubber transmissions mount keep braking went throw like 4 of them is there a better one that I can use or something I can do to make them last longer?
Please give me your best advice =)
Old Jan 29, 2012 | 11:15 PM
J0386's Avatar
Car: 1988 formula firebird 350
Engine: 350 tpi
Axle/Gears: Bw 9 bolt 3.27
Re: Transmissions Mount Problems!
any of these should work good for u i had the same prob with my 305/auto would break almost once a month till i got an ES poly mount and has had no trouble, u can also get one at your local parts store
http://www.summitracing.com/search/Y...s/?Ns=Rank|Asc
Old Jan 30, 2012 | 12:17 AM
'84thunder's Avatar
Car: 1984 Camaro sport coupe
Engine: 5.0(H/O) 305 carb'd
Transmission: TCI St. Fitr stge 2 700r4 man.valve
Axle/Gears: stock gears, Limited Slip
http://www.summitracing.com/search/Year/1986/Make/PONTIAC/Model/FIREBIRD/Department/Chassis-Suspension/Section/Bushings-Mounts/Part-Type/Transmission-Mounts/?Ns=Rank|Asc
get the prothane ones. way better
Old Jan 30, 2012 | 12:21 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Is your torque arm bushing and are your engine mounts in good shape? I used to have problems with the tranny mount breaking and then clunking around until I found out that my torque arm bushing was obliterated.
Old Jan 30, 2012 | 07:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As Lucid suggests, you may wish to take a peek at other mounts (or your driving style), because breaking four mounts with a 2.8 seems excessive. The poly and/or Prothane mounts, while stronger, may cause vibration issues that you can't live with--at least I couldn't. Below is a comparison of all three mounts: ES poly, Prothane, and OE rubber:
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Street Lethal
Apr 30, 2019 12:14 PM
Omega
Oct 1, 2015 02:20 PM
Bert87
Aug 23, 2015 03:50 PM
sreZ28
Aug 14, 2015 07:48 PM
