T-56 Clutch Fork question
Old Feb 5, 2012 | 03:13 PM
Ricco's Avatar
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
Just got the trans mounted up to the motor, but even after having pushed the clutch fork onto the throwout bearing, it still seems awfully loose.. Should it be like this or did I do something wrong?
This isnt my video but mine is just like this..
http://www.youtube.com/watch?v=2RZmd...ature=youtu.be
Old Feb 5, 2012 | 09:05 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T-56 Clutch Fork question
https://www.thirdgen.org/forums/tran...utch-fork.html
Old Feb 6, 2012 | 09:56 AM
Ricco's Avatar
Engine: 350 HSR
Axle/Gears: 3.43
Yeah, I made sure that the pivot T was securely tightened down.. I guess I mean that there seems to be more play than I would of expected, but it is in the direction of normal travel of the clutch fork.
Old Feb 11, 2012 | 05:59 PM
Ricco's Avatar
Engine: 350 HSR
Axle/Gears: 3.43
No-one knows if this looks normal or not??
Old Feb 11, 2012 | 06:24 PM
Twin_Turbo's Avatar
Do you have it properly seated around the bearing collar??
Old Feb 11, 2012 | 06:42 PM
Ricco's Avatar
Engine: 350 HSR
Axle/Gears: 3.43
Yeah, the play is coming from the fact that the spring on the fork doesn't hold the fork tight to the pivot.. Even with the tranny out and the fork pushed in, it rattles around on the pivot. If it shouldn't be like that, the only way to fix it would be to replace the spring on the fork or the fork itself.. Since the spring is riveted to the fork it may need a new fork.
Old Feb 17, 2012 | 01:58 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Wait a second.... is this the source of that rattling marbles T56 sound in neutral?
Mine's always done it, I've read about a LOT of people who have had T56's that did that from day 1 and just dont worry about it, so I never worried about it either. But I've just had a eureka moment over it. I dont hear it in gear for some reason, but in neutral at a stop with my foot off the clutch pedal you definitely hear a very obvious rattling in the trans.
By the way my fork acts about the same. I never was all that concerned about it. When the slave cylinder is installed it will keep tension against it and Im sure thats how GM intended it.
Ghettobird52
Apr 21, 2020 08:44 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
rsrmoore
Aug 7, 2015 08:44 PM
