Aftermarket speedo driven gear shafts
Car: 81' Z28, 87' Iroc Z28, 05' GMC Z71
Engine: LB9 - 305 TPI - 190 H.P.
Axle/Gears: G92 - 3.23
Are all aftermarket speedometer driven gear shafts made plastic, as a single piece unit?
My current driven gear is a plastic gear on a metal shaft, with a plastic housing. My new cable won't spline into the shaft so i started checking to buy a new driven gear. I haven't been able to find one like I've described that's metal, they're all made out of plastic.
Re: Aftermarket speedo driven gear shafts
68 vies, no replies. Come on guys.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Year and type of trans?
JamesC
JamesC
Car: `86 SS / `87 SS
I haven't shopped for 700 speedo gears in a while but plastic ones can last a pretty healthy amount of time.
The better question is why the new speedo cable won't fit the old gear shaft.
TCI's catalog shows the plastic ones.
MY old cable froze up so i got a new unit from car-quest. I've got the trans out the car right now, so i pulled the speedometer gear/carrier unit out. I screwed the cable on to the carrier but they wouldn't mesh. When i spin the gear, the cable won't turn. I figured the inside of the shaft must be worn? What am i missing?
Theres a small portion of cable broken off inside the metal shaft. Cant seem to pick it out. Ive tried gluing something to it, but its in there pretty good.
1992rs/ss
Jan 31, 2025 05:10 PM
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
700, aftermarket, cable, calalog, driven, fit, gear, gearshaft, market, shaft, speedo, speedometer, steel, transmission, wont
