700r4 Speedo Elec./Mech.
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Is the 700r4 Speedometer a Electrical or Mechanical setup?? I want to order new gears from here But not sure.
http://www.monstertrans.com/store/ca...dometer-Setup/
Never Mind its Mechanical, does that mechanical setup have everything I need?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 700r4 Speedo Elec./Mech.
JamesC
Car: 92 Camaro RS
Engine: 305 TBI
Car: 92 Camaro RS
Engine: 305 TBI
Would you happen to kno if you gotta calibrate an electric speedo?
Car: 92 Camaro RS
Engine: 305 TBI
I found this, Not sure how true this is... http://www.autometer.com/tech_faq_an...x?sid=2&qid=40
Car: 92 Camaro RS
Engine: 305 TBI
I must be confused, I thought u gotta change the drive and driven gears if its mechanical... and I thought the electric speedometer can be calibrated with a calibrator hooked up to the ECU.
JamesC
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
all you have to do on the last of the 90/92 700R4s is to buy the right to gears. and pop them on the VSS.. like from 3.23 gears to 4.11(mine is the white VSS) they also make a black one)
the 3.23 gear on the tail shaft is red. you need the green/gray gear. the gear on the VSS will stay the same. with this swap. (just a exmple) easy easy
some times you will swap the gear on the tail shaft and the gear on the VSS.
parts are about $12 ea
Car: 1986 Camaro Z28
Engine: 385" SBC
Transmission: built out 700r4
Axle/Gears: 4th gen, 373, LSD, GIRDLE
so how do you switch from a cable driven speedo to a electronic one? say you wanted to buy a set of gauges...like the ones on hawks thirdgen?
rs_z28_vert
Sep 30, 2015 09:47 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
700r4, auto, calibrate, electrical, gauge, mechanical, meter, sensor, setup, speed, speedmeter, speedo, speedometer, transmission, vehicle
