Rear Wheel Bearings
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Rear Wheel Bearings
Hi,
Was going to replace the rear wheel bearing on an 82 Firebird I am restoring. It has no Engine or Transmission at the moment. It is a standard axle and had a 3 speed automatic transmission. I called up to order some rear bearings and was asked did I just want the bearings or the repair bearings. How am I supposed to know that. I am confussed now as to what I need.
What goes wrong with the back axle that repair bearings are needed. Is it on the wheel side that things go wrong or further up. I jacked up the car and twisted the wheels and there is a noise, sounds like the shaft moving on the bearings but should I hear that noise. Don't hear a whine. The car has been stood for a good few years so maybe there isn't enough grease on the bearings.
Would appreicate if someone could explain.
Thanks.
Thanks.
Re: Rear Wheel Bearings
Was going to replace the rear wheel bearing on an 82 Firebird... I called up to order some rear bearings and was asked did I just want the bearings or the repair bearings. How am I supposed to know that.
For me, new axles, bearings, and seals.
Note posts #6 and #7:
https://www.thirdgen.org/forums/tran...ing-axles.html
BTW, differential fluid lubes the bearings.
JamesC
1992rs/ss
16
01-28-2016 09:58 PM
kah992
08-19-2015 02:55 PM
