need help/advice rear gears
Old Mar 1, 2012 | 09:53 AM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
I am thinking of changing the gears in my car for better performance my car doesn't see the highway if it does its for one exit I should have 3.08's if its stock I would like to I think go to 3.73 I have a 350 tpi motor and a 700r4 trans been having a difficult time trying to shop for the gears so any links and advice I would appreciate.
Old Mar 1, 2012 | 10:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: need help/advice rear gears
Many members says that 3.42's are the best bet for a 700R4. A bit of research might ease your mind on that score. The 10-Bolt FAQ sticky will provide some general info about 10-bolts that may be useful (assuming that's what you're running):
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Mar 1, 2012 | 05:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Even if you see some highway use, 3.73 won't be too bad but with the low first gear of the 700R4, such a deep gear isn't really needed. a ratio in the mid 3's is better.
Old Mar 1, 2012 | 05:29 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
I had 3.42s in my car when i bought it and wouldnt go any more than that with a 700. I actually really regret getting rid of it for this damn 9 bolt lol.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
