Driveshaft measurements
Old Feb 29, 2012 | 11:11 PM
onebadd86t/a's Avatar
Car: 86 trans am
Transmission: 700 r4
Axle/Gears: 3.42 posi 10 bolt
Does anybody know what the length of the driveshaft for a 86 t/a with a 700r4 trans is ?
Old Mar 1, 2012 | 07:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Driveshaft measurements
In answer to your specific question: 41 1/2" from center of the U to center of the U, for both the auto and manual.
JamesC
Old Mar 1, 2012 | 05:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The same length as 84-92 third gen driveshafts with a 700R4. 82-83 may have the 200c which uses a different length.
You won't find a driveshaft in any other car the proper length for a third gen except maybe from a fourth gen. If you want to get one custom built, the measurement is from the center of the u-joint on the diff to the center of the u-joint on the tranny yoke but the tranny yoke must be installed into the transmission then pulled back out 1" before taking the measurement.
Old Mar 1, 2012 | 05:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
FWIW, 4th gen aluminum shafts are 40.5 center to center
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Elephantismo
Feb 13, 2019 12:51 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
loud91rs
Oct 5, 2015 10:05 PM
AUZ28
Oct 3, 2015 06:28 PM
