3.27 vs 3.73 with a T5
Old Mar 1, 2012 | 10:17 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I have a set of 3.73 gears in a 10 bolt now. I am looking at a 9 bolt with 3.27, I was wondering how much difference will I notice?
Sometimes I do feel the 3.73 are a little short but I am not sure, anyone have any experience?
Old Mar 1, 2012 | 10:45 AM
Abubaca's Avatar
Re: 3.27 vs 3.73 with a T5
I have a 3.27 right now with a T5 and a long tube runner intake. With the torque and low revs, I think I "might" go to a 3.45, but I like the 3.27.
....I would imagine with a carb, you'll want to stay with the 3.73.
Old Mar 1, 2012 | 10:53 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
I had 3.27s then went to 3.45s huge difference never did 3.73s. For just a bolt on car she ran 13.77 at 3700'da and ran 13.1 in Houston all on radials
Old Mar 1, 2012 | 10:54 AM
midias's Avatar
Why with a carb would I want to stay 3.73?
Old Mar 1, 2012 | 11:09 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Is your powerband similar to the L69 (shift in the low 5000s rpm) or higher? It doesn't take much cam to push it up higher.
If it's a 2.95 / .63 geared T5, I would continue with the 3.73s unless you want a highway-use car.
Old Mar 1, 2012 | 11:13 AM
Car: '88 Trans Am
Engine: 5.7L TPI
Oh and my tyranny selection was from the TBI 305 cars since it had a steeper 1st gear
Old Mar 1, 2012 | 11:27 AM
midias's Avatar
Yes the powerband is 1800 to 6000 and it is a 2.95 / 0.73 trans
I mostly use it for a summer runner when I am not on a motorcycle.
Old Mar 1, 2012 | 01:29 PM
jmd's Avatar
jmd
Steeper than what? The 2.74 first gear which I've never seen?
If it is the .73 fifth, pull it and swap that to the .63 fifth. Problem solved and gas money saved.
Old Mar 1, 2012 | 01:36 PM
Car: '88 Trans Am
Engine: 5.7L TPI
The TBI cars had a different gear ratio than the the TPI cars.... my car launched 1.93 60' times with the TPI granny and was 1.73 with the 91 TBI granny.
92projectcamaro
Dec 8, 2015 12:25 AM
92projectcamaro
Sep 29, 2015 07:07 PM
JSDaddy189
Sep 26, 2015 03:50 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
whyt86roc
Sep 10, 2015 10:03 PM
