Tranny Pan Leak
Old Mar 4, 2012 | 07:42 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Tranny Pan Leak
My 700R4 transmission pan is leaking from the passenger front side. I've replaced the pan and I've used 3 different gaskets (cork, rubber, and permatex).
I'm currently using Perma-Tex transmission gasket. I used extra gasket on the passenger front side to seal the deal, so to speak, but no luck. The leak is indeed coming from the seal and not from anywhere above.
I'm at my wit's end over this. The tranny is only leaking when the engine is running. Any clues?
Old Mar 4, 2012 | 08:36 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Tranny Pan Leak
I would put a straight edge on the pan to make sure it"s not bent. You could be over tighten the bolts to the pan. Make sure the trans is free of gasket material. I have a stock pan I'll give you, if you want to pay shipping, which i would keep at a minimum.
Old Mar 4, 2012 | 09:27 PM
Engine: L69
Transmission: A4
Re: Tranny Pan Leak
The pan is brand new and both the pan and the tranny are straight, I completely cleaned both as well. I also torqued the bolts to 85 in lbs. This is why I'm at a complete loss.
Old Mar 4, 2012 | 09:41 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Tranny Pan Leak
run your pan bolts down hand tight.. then snug them just a bit..
also make sure. that none of your. pan bolt holes. has bin over drilled to deep into the case. (have seen this before on another tranny)
if so you can use Ultra Blue/black RTV on the pan bolt in that hole.
Old Jul 8, 2013 | 10:26 AM
Camarobreaker's Avatar
Car: 1989 IROC-Z
Re: Tranny Pan Leak
check all of of your tranny cooler lines, your tv cable needs a grommet in it as well as your dipstick tube. check them all, they can leak just as easily as the pan and it looks exactly like its the pan leaking.
Old Jul 8, 2013 | 10:35 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Tranny Pan Leak
gta892000
Aug 11, 2019 11:16 AM
Stryker412
Sep 7, 2015 09:11 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
