4th Gen Rear End Swap
Old Mar 5, 2012 | 09:52 AM
88Camaro1993's Avatar
Car: 1988 Camaro IROC-Z28
Engine: 305 V8
Transmission: Automatic
Axle/Gears: Posi
Alright. I dont know where to post this...bear with me please...I want to get rid of my 88 Camaro's rear end and replace it with a 4th gen disc posi rear end. 1.Because I hate drum brakes 2. Ive heared somewhere the 4th gen rear ends are wider (I like that look)
So i would like to know what I need to buy to do a complete swap.
Differential
Master Cyl?
and of course, Re-bent Brake lines right?
Any help would be greatly appreciated!!!!!
Old Mar 5, 2012 | 10:04 AM
Mudluver27's Avatar
Car: 1988 Firebird
Transmission: 6-speed
Axle/Gears: 2001 ss 10 bolt 342's
Re: 4th Gen Rear End Swap
You need the master from a 3rd or 4th gen, need 4th gen calipers, rotors and pads, and fittings to adapt the 3rd gen lines to 4th gen calipers. And a proportioning valve.
I did this swap but already had rear discs so no need for proportioning valve or brake master. 4th gens do stick out about 2 inches wider and look stupid with 3rd gen backspacing IMO. Get some 4th gen wheels and 2 inch spacers for the front 4th gen wheels. They look good that way.
You may or may not need more or less stuff, this is just from my experience. I am sure someone with more knowlege will chime in. Good luck and post pics when done.
Old Mar 5, 2012 | 10:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the 10-Bolt FAQ in the sticky section for info on the swap: master, combination valve, parking brake cables, speedo gears, etc.
JamesC
Old Mar 7, 2012 | 12:18 PM
Engine: 305 V8
Axle/Gears: Posi
Thanks guys. I gotta do some research and saving. Itll take me awhile....
Old Mar 11, 2014 | 03:55 AM
monster34's Avatar
Car: 82 camaro Z28
Engine: 383
Transmission: 400 turbo
Axle/Gears: gen 4 10 bolt, 3:73
hey hello I have a forth Gen rear end in mine, the biggest issues are around the width
although I'm running 8.5 x18s with a +30 off set on my rear wheels and havent looked back can supply pics of the setup if you like but not a huge difference except hand brake etc and 50mm wider,
hand brake cables were custom made to fit and speedo is about 20km out
Old Apr 27, 2014 | 03:35 PM
bttrflybird's Avatar
Car: 89' Bandit 2 #104 of 500
Engine: LS1 5.7L
Transmission: 4L60e
Axle/Gears: 3.23 posi
i cant find a clear answer??? i have 89 firebird and i swapped in a 4th gen posi rear, and i want to know if i still need to run 2inch spacers or spaceers at all? my rims are c6 zr1's 18x9.5.
Old Apr 27, 2014 | 06:46 PM
monster34's Avatar
Car: 82 camaro Z28
Engine: 383
4th gen are 50mm(2") wider so aftermaket wheels need to have a minimum of +30 offset to avoid rubbing or looking like Joe Dirts car
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
