Rear end noise HELP PLEASE
Old Apr 27, 2014 | 10:11 PM
89CamaroAndrew's Avatar
Car: 89 Camaro Rs
Axle/Gears: 3.45 9 bolt
i can hear a noise coming from the rear passenger side. it starts making noise when the car starts moving. im not sure if it is the axle or rear brakes. i just put on this differential and it had a really worn out brake pads and worn out rotor on the passenger side. i changed both sides and it still makes the noise. the passenger side also has a leak and it gets really hot so im wondering if it could be the brake caliper or something with the diff. please help thank you.
Old Apr 27, 2014 | 11:05 PM
Car: 89 Camaro Rs
Re: Rear end noise HELP PLEASE
anyone?
Old Apr 28, 2014 | 07:07 AM
big gear head's Avatar
If the axle seal is leaking then there is a very good chance that the bearing is bad. If that is the case then the axle will have to be replaced along with the bearign and seal.
Old Apr 28, 2014 | 04:53 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
You could try supporting the rear on stands with the wheels off the ground, chock the front wheels, park brake off and run it in gear and go listen to the suspect places. You should be able to tell if it's in the center (diff) or at the wheel (bearing?). If it's at the wheel check the run out on the rotor. Check it's centered in the caliper bracket etc. and caliper isn't binding.
Old Apr 28, 2014 | 05:29 PM
Car: 89 Camaro Rs
i lifted the car up and put it in drive and two people told me that the noise is my new brake and rotors and it kinda sounds like a high pitched noise kinda like a grinding or scraping, its hard to describe.
Old Apr 28, 2014 | 05:32 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
the wear tab on wrong?
They put a tiny tab of metal on some, to do that, to warn you te replace them.
Old Apr 28, 2014 | 05:41 PM
Car: 89 Camaro Rs
im gonna rebuild my caliper tomorrow and i dont think thats it but its worth looking at.
Old Apr 28, 2014 | 05:51 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I break em off n remove em, as it can be real annoying, its done to save your rotors.
Old Apr 28, 2014 | 05:53 PM
Car: 89 Camaro Rs
to be honest i remember breaking them off now on both sides...
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
