Overdrive slipping after stealth ram install?
Old Mar 6, 2012 | 06:13 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
I installed a stealth ram on my camaro and now overdrive instantly started slipping under hard to moderate throttle. I adjusted the TV cable several times with no change and fluid level is correct. 1st 2nd and 3rd are strong and no slipping.
If you drive the car normal you wouldnt even notice, but if your riding 60mph and give its some gas(passing a car) it revs up the rpm's. You can feel that its still got some friction, by that I mean it dosent seem like i just dropped it in neutral the car gains speed.
Also if Od is on its way out when it does go will it take 3rd with it? The reason I ask is because I dont wanna go anywhere and be stuck with just 1st and 2nd gear. Im ok if ive gotta limp home in 3rd gear, lol
thanks for any help guys,
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
