Drive Shaft Removal.
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Trying to remove the Drive Shaft from the rear axle and having some difficultly. On the service manual it says to remove the bolts and seperate the drive shaft from the pinion yoke and withdraw the slip yoke from the transmission. Sounds easy enough but once I remove the bolts how do I seperate it from the yoke on the axle. It won't budge. Don't want to go hammering it as the manual says that could damage the bearings inside the bearing caps. I tried a bar to see could I get it to move. The only other thing I can think to do is disconnect the back axle and try and move it back to get the slip yoke out of the transmission but not sure how to get the axle section removed.
Anyone any suggestions,
Thanks.
Thanks.
Car: `86 SS / `87 SS
Re: Drive Shaft Removal.
Prying is correct. You simply don't want to bend the driveshaft yoke ears. I don't know how humid and salty a life the car has lived, but a penetrating oil at the u-joint caps may be helpful.
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
since your pulling the DS out, and the u-joints are clearly old they should be replaced - hammer away (within reason) and have new u-joints pressed in
Engine: 2.8 V6
Hi,
I have tried penetrating oil and a light tap with a hammer but no joy. I will try and pry it again tomorrow. Wasn't sure if prying it was the right thing to do but if it is I will give it another go tomorrow.
Thanks.
Thanks.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Big prybar or very long screwdriver and the caps should pop out of the diff yoke. Don't be afraid to put a little force behind it. It's unlikely a prybar will cause any damage unless you hit yourself with it when the caps pop.
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
Car: 1987 Trans Am
Engine: LQ9/L92
as already mentioned, a long screwdriver or prybar should do the job just fine.
if you have the original u-joints in there, bear in mind the plastic retainer that's holding the caps in place; a torch should get them to worm their way outta the weep hole in the DS
I did actually hit myself on the head with the prybar
Car: 1987 Trans Am
Engine: LQ9/L92
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
1992rs/ss
16
Jan 28, 2016 09:58 PM
Ozz1967
Aug 16, 2015 10:23 PM
