B&m shifter cable problems
Old Mar 26, 2012 | 08:12 PM
black sunshine's Avatar
I'm new to the site and I just bought a 92 z28 it has been board over 30,And has a mild cam and is in good shape for the year. My problem is the guy before me put in a B&M shifter and it is very hard to get it into drive and the shifter is very stiff should I replace the cable or put the factory shifter back in, it also came with the car, What would you guys do... Thanks for your input.
Old Mar 26, 2012 | 08:19 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: B&m shifter cable problems
Hello welcome to third gen If it was me I would crawl under the car and see if the cable has a tight bend that will need to be removed by routing a different way.
Old Mar 26, 2012 | 08:24 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Mine is the same way, i've been rebuilding my motor so I still haven't adjusted it. You'll have to do a search around here, there is a nice diagram that shows how to wire needs to be, and if there is a bend or kink it is hard to shift like you said. It is really hard for me to put it into first without slamming it into gear
Old Mar 26, 2012 | 08:33 PM
I will check out how they have it routed and look at the diagram to make sure it is right, because I like the way the B&M shifter looks.. over the stock looking shifter.
BewleyBizzIROC
Feb 3, 2020 09:52 AM
deracer
Apr 11, 2016 12:04 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
neekolzun
Aug 24, 2015 04:59 PM
