3.73/Disc brakes
Re: 3.73/Disc brakes
L69 cars. 5-speed for sure, but only some of the auto ones.
Problem is, those will all be the crappy Saginaw (cast-iron) brakes.
Yes, some were originally equipped with posi. Not many, but some. Whether you could still tell that by their behavior is anybody's guess.
If i were to call a junkyard or go to one myself to pull it, which years should i be looking for a 3.73 rear?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
Hrm, you can tell what rear end is in a car (assuming it hasn't been changed) by the vin? What would an 86 with a 8th digit of H have in it? I've been meaning to try and figure out what rear I have in mine, and I'm pretty sure it's original stock.
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
You can look under tech data on the main site for your year and model and it will tell you what gear ratio they came with.
8th digit H = the base-model V8, LG4
Most likely would have come with 2.73 if auto, 3.08 or 3.23 if stick
Changed the fluid lately? I thougt not.
While you're catching up on the past-due maintenance, make a point of looking.
While you're catching up on the past-due maintenance, make a point of looking. Member
Guess I'll still do the wheel rotation trick to find out for sure at some point.
Saw your ranting about that in another post haha. There is no point in me doing a fluid change in my rear end right now. I'm going to be putting a new posi and gears in it at some point in the next couple of months, it'll get new fluid then and a few hundred miles after as well. Thread
dbrochard
Sep 19, 2015 08:13 PM
