speedo gears cannot find anywhere!
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
i need a 45 driven gear for my 3.42 700r4.
cant find it nowhere!! so i found a 44 driven gearm ordered it and got a email stating my money was refunded due to the part being out of stock. . .
Im at a lost, looked every where for this lil gear.. So if anyone can throw me a bone here mostly appreciated,
cause i cant find the gear i need anywhere!!!
plz help
have the stock 2.73 drive gear, (wich is a seventeen) did the math and a 45 was the conclusion. should work.(with the 245/50/r16 (the stock irocs))
thanks to all
plz help
thanks to all
Car: `86 SS / `87 SS
Re: speedo gears cannot find anywhere!
so re-do your math to figure out the driven to go with a 15 tooth drive.
Research the VSS; some fit higher tooth counts; some lower.
(I'm in no way affirming the tooth counts you've indicated.)
I thought the 45 driven for VSS was AWOL anyhow.
Car: 1984 camaro
Engine: 1970 l48 with vortec heads
Transmission: 700-r4 from a diesel
you can use a 44, order from classic industries or ebay.
Car: 92 firebird
maths n correct if i did it with a 15 i couldnt find a 40 driven to go with 15 drive gears anywhere why i was going to keep the stock 17 drive gear and use a 44.
bought it from ebay have to try classics industries
ambainb
Apr 25, 2016 09:21 PM
beachrodder
Aug 7, 2015 04:27 PM
