tranny grinds
Old Apr 12, 2012 | 07:45 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
tranny grinds
Ive got a th350, ran good when i pulled it out of my old firebird, 4 years later stuck it in a camaro, now it grinds when i shift under hard throttle. Started behind a decent 400 has a shift kit with 2400 stall, now sits behind a almost stock 360 with a 1800stall.
Old Apr 12, 2012 | 07:53 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: tranny grinds
That's a hard one I don't know but could the linkage need to be adjusted maybe it is holding it between gears just throwing an idea out there.
Old Apr 12, 2012 | 08:21 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Re: tranny grinds
Ill check into that. Thanks
Old Apr 12, 2012 | 08:52 PM
Edwardgp's Avatar
Engine: 454-350
Re: tranny grinds
OK and don't forget to keep us updated maybe we will need to help you more.
Old Apr 14, 2012 | 03:18 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Re: tranny grinds
I dont have the kickdown cable hooked up, would that make it goofy? Cable on the trans is good. It shifts good still churps tires into second, just grinds slightly.
Old Apr 14, 2012 | 04:05 PM
Edwardgp's Avatar
Engine: 454-350
Re: tranny grinds
I think you need to get everything hooked up and then let us know what you got'
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
