Pressure plate friction surface
Old Apr 14, 2012 | 07:29 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
How do you guys feel about a pressure place that has a surface that is obviously done in a lathe? I noticed that both my Phoenix race clutch, and autozone cheap clutches have like the lines in it (looks like a record), vs the swirls of a blanchard grinder.
I know if a flywheel is like that, we usually throw 'em in the garbage.
-- Joe
Old Apr 15, 2012 | 12:06 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Pressure plate friction surface
For a pressure plate, it probably doesn't matter. It's unlikely anyone has tried to machine it to make it true again. When a clutch fails, the pressure plate should be replaced but the flywheel can always be ground until it reaches minimum specs.
All the pressure plates that I've seen have never had the swirls.
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
someone972
Aug 30, 2015 12:52 AM
