drive shaft help!!
Old Apr 19, 2012 | 11:44 PM
ChevyFreek's Avatar
Car: 87 camaro/ 78 gmc serria classic
Engine: 2.8 soon to be 350/ 350
Transmission: 700r4/ turbo 350
Axle/Gears: have no clue.
drive shaft help!!
Doing engine swap, from a 2.8 to a 350, the 2.8 has a 700r4. The 350 will have a 700r4, my question is will i need a new drive shaft or are they the same size?
Old Apr 20, 2012 | 12:29 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: drive shaft help!!
Position of the transmission doesn't change.
Old Apr 20, 2012 | 12:35 AM
ChevyFreek's Avatar
Ok, will i need a new crosmember?
Old Apr 20, 2012 | 07:09 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
4 the trans? No. 4 the motor? no. you will need to move the Kmember motor mounts to diff holes.
Old Apr 20, 2012 | 08:53 AM
Hollywood383's Avatar
Car: 92' Camaro RS
Engine: 383 Stroker
Transmission: M5
Everything will come together just fine. Like TTOP said the motor mounts are the only thing that move.
Old Apr 23, 2012 | 12:49 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
In the process of moving the motor mounts you will probably need to rebend brake lines slightly, should be no problem. I am putting in a V8 and T56 and can reuse my driveshaft and motor mounts, after moving, but need a new transmission crossmember (T56 mount is further back). When I do the swap I will pull front coil springs to have better access to motor mount bolts inside the K member and for replacement.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
Ozz1967
Aug 16, 2015 10:23 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
