PLEASE GIVE ADVICE 700R4 Will not Manually Downshift
Old May 11, 2012 | 10:51 PM
cwv2's Avatar
Car: 1991 Chevrolet Camaro Z28
Engine: T.P.I. 305
Transmission: 700 R4
Axle/Gears: Richmond 3.73
I have a 91 Camaro Z28 with a 305 and a 700R4.
It upshifts great using the shifter or if placed in overdrive and left there.
The problem is, if I try to manually downshift it from a higher gear to a lower gear it will not pull in the lower gear unless I get the RPMs up.
I guess that I am saying I can downshift and the car does not slow down. It is like I shifted into neutral instead of a lower gear.
I checked the fluid and the level is past full, which I know that is was not before. The fluid does not smell burnt and the color looks like it did the day I changed it.
Please only give me your opinion if you know what you are talking about.
Thanks to all!!
Old May 12, 2012 | 06:57 AM
cwv2's Avatar
Engine: T.P.I. 305
Re: PLEASE GIVE ADVICE 700R4 Will not Manually Downshift
Old May 12, 2012 | 10:59 PM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
you might be losing pressure in your pump do to manually downshifting an automatic transmission.
Old May 13, 2012 | 06:57 AM
cwv2's Avatar
Engine: T.P.I. 305
I have read many posts andmany cars have had the same symptoms as mine. It seems liek everyone points toward the overrun assembly. I do downshift the car manually quiet a bit, but never to the point of breakage (or at least I thought). Either way, I am taking the tranny out and having it rebuilt.
I will try to post the results of the rebuild and what happened for anyone having the same problems in the future.
Old May 17, 2012 | 01:11 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Just have a manual valve body installed while its out and problem solved
jhawkeye
May 25, 2022 06:33 PM
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
stalkier
Aug 21, 2015 01:54 AM
formula_novice
Aug 18, 2015 08:48 PM
