newbie 700r4 question
Car: 88 ta
Engine: tpi 305
i just got a 88 trans am last week and notice that my car shifts great in all gears if i stay under 2500 rpms. if i get closer to 3000 rpms it will slip a little. the harder i drive it around 3000 rpms the worse it slips. anyone have any idea what the problem is? thanks
Car: 88 ta
Engine: tpi 305
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Re: newbie 700r4 question
I don't think it would cause the tranny to slip, but too much fluid is just as bad as too little.
Car: 88 ta
Engine: tpi 305
ok, thanks....i was hoping that that was going to be the trouble....i'll try the fluid change...when i change the fluid.....should i put some lucas transmission fix in it while im there? or just fluid? what would be the best fluid to put back in there?
Car: 88 ta
Engine: tpi 305
also, if it still slips after the change, does anyone know a website that sells rebuilt stock 700r4's for cheap? im just driving the car as a dd and stock would be fine. or should i be able to get it rebuilt for less money?
Car: 01 Acura TL
Engine: 3.2 Vtec
Transmission: 5 speed
Axle/Gears: ?
you can add some luca but just make sure you dont overfill it after u top it off with tranny fluid and i say go with some mid-grade trans fluid like autozone brand or any like that and if it works just fine change it out 2 mobil1 the next 4-5 months and try craiglist.org i always fine cheap good working parts on there
Car: 88 ta
Engine: tpi 305
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Over here they'll charge you upwards of $850 for a 700r4 rebuild, maybe you can get a used one in trade for the one you've got and pay a lower price but I find deals on Craigslist every now and then like for example I just found a guy selling his 305 motor & his 700r4 trans for $600 both run fine.
Car: 88 ta
Engine: tpi 305
Iroc8t8
May 4, 2026 08:09 PM
