2 quick questions with some fluff...
Old May 17, 2012 | 10:53 AM
DufussMan's Avatar
Car: 87 Trans Am
Engine: 305 tpi
Axle/Gears: 2 series 2.73 drum
Just brought my 87 trans am (305 tpi w/ 700r4) into the shop for some jobs that I didn't want to do. One of which was swapping stock steel driveshaft for an aluminum one I got from another f-body. The guy then calls me and tells me he didn't think the shaft would fit. I tried to tell him it would but then just said forget it do the other stuff. So......
Aren't all f-body aluminum driveshafts universal from like 84 on up? I checked the number on mine and its definetly came off a late 80s f-body. I think the shaft is like an inch shorter but the yokes are an inch longer...
Mechanic quoted me at least 2 hours for just the driveshaft swap. Really!? This seemed like a lot since the cars on the lift for a bunch of other rear end stuff anyway. Or am I being a cheapskate?
Thanks as always guys. Just some quick input needed I don't post much
Old May 17, 2012 | 11:44 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 2 quick questions with some fluff...
A driveshaft swap is about 2 minutes, if he forgets which way the bolts turn halfway through.
Old May 17, 2012 | 11:55 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Sounds high to me, it didn't even take me an hour to do it including changing out the U-joints and I'm no mechanic. I'm not sure what years are interchangeable though, hopefully someone else can answer that. Mine was an aluminum driveshaft out of a 4th gen.
Old May 17, 2012 | 11:58 AM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Lmao
Old May 17, 2012 | 12:36 PM
DufussMan's Avatar
Car: 87 Trans Am
Engine: 305 tpi
Thanks for the input. They're universal right?
Old May 17, 2012 | 12:38 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They're interchangeable, except the TH200C shafts.
Old May 17, 2012 | 01:04 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Thirdgen shaft RPO JG1 (GM p/n 10085375 located on the tail of the shaft) will fit, period.
Two hours sounds correct--with a break to swill a 12-pack, throw up twice, and have a nap.
JamesC
Old May 17, 2012 | 09:21 PM
I think I'd pass out halfway through the 12, puke 4 times, and get a good night's sleep... and STLL beat your 2 hrs. You must weigh ALOT more than me. Like, over 175 or something.
Old May 21, 2012 | 05:11 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
The only way that could take two hours is if the person doing it has two broken arms or arthritis so bad that the can't turn a wrench. If I was doing it and taking my time I could not make it last more than 30 minutes and that is counting the time to jack it and when finished take it off the jack stands.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
