12 bolt question
Old May 22, 2012 | 05:33 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
12 bolt question
would a 1970 12 bolt (lemans) non posi fit in a 86 firebird? I know its kind of a stupid question :P but please bear with me. Also can I make the non posi into a posi?
Old May 22, 2012 | 05:39 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: 12 bolt question
Width-wise? I dunno. But I do know that it would have to be modified suspension-wise to accommodate the LCA/coil spring setup if your retaining the stock suspension.
Old May 22, 2012 | 05:43 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
Darn. sounds like a pain in the tookus lol. so you suggest a moser unit then? how many spline should I get? I just want to be sure it can handle 50ft'.lbs of torque. I only plan on making up to 450 but the better its rated the safer I feel.
Old May 22, 2012 | 05:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if you do a 12 bolt, use the strange one. Mosers is known for torque arm bolt retention issues as well as other mosers related complaints.
30 spline is enough for most people. If you plan to drag race it a lot with sticky tires, go bigger, 33 or 35
Old May 22, 2012 | 05:57 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
I'd classify myself as high performance street. not much racing but driving fast and just pleasure cruising, maybe the odd trip to the strip. Is there a website for the strange axles other than the strange engineering page? theirs is confusing.
Old May 22, 2012 | 07:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
www.spohn.net
He's a TGO supporter and can provide you with everything you need.
Old May 22, 2012 | 07:54 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
I heard spohn sucks though :/
Old May 22, 2012 | 07:58 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
From who? do a search on here of their name. They have a very good reputation and some nice stuff.
Old May 22, 2012 | 08:23 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
I heard the torque arms and all that are clunky. I want BMR stuff. but honestly which is better? Moser or Strange?
Old May 22, 2012 | 08:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Of the 12 bolt, strange.
Old May 23, 2012 | 08:38 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Take a look at autoweldchassis.com I have one of there ford 9 rears and there torque arm has to be the strongest in the business. It is made of tubular steel with cross bracing. It bolts to the crossmember they send you with a heim joint and bolts to the top of the rear and also to the bottom of the rear with heim joints (fully adjustable). I have never seen its equal unless on a few all out trailered drag cars.
Old May 24, 2012 | 12:02 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
If the length is right, its really not that hard to fab up that rear for our cars. I have basic welding and fab skills and did one for mine and it turned out great. You just need to be creative on the TA mount, that was the hardest part. If you can do it, it cost about 1/3 to half what a strange costs depending on what extras you get. I spent about 900 or so on mine and it is essentially new, gears, axles, bearings and brakes. Bostoncamaro is doing a great write up on the one he is doing in the fabrication section.
Old May 24, 2012 | 12:08 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
I contacted spohn and they said strange is worth it, but I'm leery cuz theres no warranty
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
