700r4 oil pump
Old Jun 3, 2012 | 09:41 PM
gmb350tpi's Avatar
Car: 89 trans am gta
Engine: 5.7L tpi
Transmission: 700r4 4 speed
Axle/Gears: borg warner aussie 9-bolt 3.27
700r4 oil pump
hey guys in have an 89 trans m gta 5.7 and i recently blew the third and forth clutch packs so i replaced the tranny with one ffrom a 91 caprice i also swapped over the valve body and governer but when i first started the car i could he a ticking slash puffing sound coming from behind the torque converter and i got a little skeptical of the pump but the car ran and drove fine, but i was at my buddies house today and he wanted me to do a burnout so i did a burnout and as i got a little bit down the street and car just revved up it was in drive but it would not move i tryed givin it gas and everything but nothing i tried puttin it in all the gears but nothing and now when i listen under the car there is no puffing sound at all...is my front pump shot or...
Old Jun 4, 2012 | 02:20 PM
Pro Built Automatics's Avatar
Re: 700r4 oil pump
You most likely broke the front pump. Disconnect the top transmission line at the transmission, and put it in a bottle and start the motor and see if you get any oil out of the line. If not, then the pump is broke.
Old Jun 6, 2012 | 10:48 PM
gmb350tpi's Avatar
Engine: 5.7L tpi
Re: 700r4 oil pump
turn out the oil pump was shot! i dropped the trans again! and pulled off the pump opened it up and found out that the oil pump rotor was snapped in half and there were pieces everywhere i changed out the pump and now she works just fine
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
