700r4 Speedometer Gear Housing
Old Jun 5, 2012 | 02:40 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Of all things to have a problem with, I swapped my converter with a 2600 rpm converter. I am finishing up, I was tightening the speedometer gear and I actually broke the threads off the speedometer gear housing.
How hard is this to replace? Is it going to leak fluid like crazy until it is replaced? Do you need to remove the tailshaft to replace it or can you just remove it from the outside? Also, anything else I might need to know is appreciated. Really dumb, I had it hand tight and decided to give it a turn with a pair of channel locks, bad idea .
Thanks in advance!
Old Jun 5, 2012 | 06:51 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 700r4 Speedometer Gear Housing
In sequence: Easy, yes, outside. Be sure to find an aluminum replacement, not the plastic versions.
Old Jun 5, 2012 | 04:51 PM
Hey any chance you know what size housing I need? I have 2.77 gears, from google I believe I need the 35-39 size housing, however the most common size seems to be 40+. I wanted to get this ordered today if possible...
Old Jun 6, 2012 | 04:59 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
What driven gear did you remove, if you're re-using it? What color is the drive gear? Correct for 245/50R16s would be red 17 tooth drive with a 37 tooth driven.
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
madsv1000
Aug 20, 2015 06:45 AM
