Engine braking feel
Old Jun 12, 2012 | 01:03 AM
BlueWrath92's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: 10 Bolt 3.42 Posi
Engine braking feel
what would make the car feel like its engine braking when letting off the gas at high speeds??
Old Jun 12, 2012 | 01:08 AM
Car: 92 Camaro RS
Engine: 305 TBI
Re: Engine braking feel
Would a higher gear ratio make engine braking stronger???
Old Jun 12, 2012 | 03:07 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
is one of your calipers sticking as that could be why as Ive never heard of a car engine braking before.
Old Jun 12, 2012 | 03:10 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Sort of.... not much though.
Make sure you dont have a sticking caliper or you've left your e-brake on or something like that, though. True engine braking will be more pronounced at high RPMs than high speeds. say 5000 RPMs with the throttle closed vs 2000 RPMs with the throttle closed. One will be a lot more dramatic. Shorter gear ratios will lead to higher RPMs at the same speed.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
