700R4 problems
Old Jun 13, 2012 | 09:32 PM
desiresk8's Avatar
Car: 86 Trans Am
Engine: 5.0 TPI V8
Transmission: 700R4 Auto
700R4 problems
did i blow my tranny? wont shift past 2nd gear. gets to about 30-40 and wont accelerate anymore and rpms shoot up. works fine in 1 and 2 on the bottom goes about 60 mph at 4000 rpms in 2nd gear. any help
Old Jun 13, 2012 | 10:37 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Re: 700R4 problems
Sounds like trannys slipping. Id bet on it being shot
Old Jun 14, 2012 | 07:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 700R4 problems
The 3/4 clutch pack is gone. Usually the first failure point on the 700R4.
RBob.
Old Jun 15, 2012 | 11:23 PM
Project86B4Z's Avatar
Car: 85 camaro RS RIP\ 86 IROC-Z :)
Engine: 2.8 MPI V6\ carbed LO5 5.7 v8
Transmission: 700r4 auto
Axle/Gears: 3.42\ posi 3.73
Re: 700R4 problems
another likely cause is the band which could be warped or worn when it engages it clamps the input drum and sun shell allowing the rear planetary to rotate engaging the 3-4 clutches.
Old Jun 16, 2012 | 12:01 AM
desiresk8's Avatar
Car: 86 Trans Am
Engine: 5.0 TPI V8
Re: 700R4 problems
i talked to somebody about it today and they said it might be the cable that goes from the throttle to tranny. he said i have to push in and adjust it or something like that
Old Jun 16, 2012 | 05:12 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: 700R4 problems
if it was the band,which clamps the reverse input drum, he wouldn't have 2nd gear or 4th.
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
