transmission lines??
Old Jun 28, 2012 | 08:17 AM
t-hale7's Avatar
hey guys, i have an 82 firebird, its a 4spd trans in it currently with a 2.8L. i am working on putting in a 350 with a th350 trans, my question is what should i do for transmission lines, some friends of mine said to use rubber hose but i think thats tacky. i seen summit racing has lines but it say they fit a th350 in a 82 camaro, i was wondering if they might work in my f-bird? i would like a set of pre-bent lines as i am not much of a fabricator, what other makes/modles/yrs of vehicle might have lines that fit relitively easily? if not and i have to fab some steel lines up what size fittings are used at the trans and at the cooler? thanks for your help.
Old Jun 29, 2012 | 08:32 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Re: transmission lines??
Yes the lines for the 82 Camaro will work as the Camaro and Firebird main structures are the same.
Old Jun 29, 2012 | 08:36 PM
t-hale7's Avatar
thank you.
AussiePr0nCar
Mar 6, 2020 04:04 PM
Reddeath210
Oct 6, 2015 08:20 AM
jer4251
Sep 1, 2015 09:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
