WC t5 in 85 cable drive Speedo..HELP!
Old Jul 3, 2012 | 09:26 AM
samtset's Avatar
I just finished the swap a WC t5 into my 85 auto Iroc. I have searched and cant seem to come up with the answer I need. I NEED to know which exact part to by and where to get them. I have also swapped out my rear end for a 3:73. Thanks
Old Jul 3, 2012 | 09:53 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: WC t5 in 85 cable drive Speedo..HELP!
You must blow at searching
In the sticky section at the top of this section FIRST post
in the post titled
Important/Useful : T-5 Drive/Driven Gear Info--Please Contribute
https://www.thirdgen.org/forums/tran...ve-driven.html
3.23's up require a blue 7-tooth drive gear, plus the following driven gear:
18 tooth (p/n 3987918) Brown = 3.23
19 tooth (p/n 3987919) White = 3.42
20 tooth (p/n 3987920) Blue = 3.45
21 tooth (p/n 3987921) Red = 3.73
22 tooth (p/n 3987922) Gray =3.77
http://www.gmpartsgiant.com/ or http://gmpartsdirect.com/ should have them
7 blue 14071731
21 Red 3987921
Sleeve 345215
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
