Should I rebuild my T5.....myself???
Old Jul 12, 2012 | 08:32 PM
leedavidalan's Avatar
Hey fellas I need your advice yet again. The 383 in my 89 Iroc killed my T5. I want a T56 but that is a year away in terms of $$$. My plan is to rebuild my T5 and baby it so that it will last until I have big $$$.
How hard is it to rebuild a V8 5-speed World Class T5?
Any recommended rebuild guides/DVDs?
Purchase the actual kit from?
And what tools will I need?
I really appreciate your time and help
Old Jul 12, 2012 | 10:42 PM
Re: Should I rebuild my T5.....myself???
Every penny you waste on that T-5, moves you a penny FARTHER AWAY FROM what you REALLY want.
Don't make that mistake. Throw it in the trash and do THE RIGHT thing instead.
Old Jul 13, 2012 | 12:09 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
What's killed on it?
Old Jul 13, 2012 | 01:59 AM
Not too sure. Shifting gradually become more and more difficult. It took about two months from when I first noticed trouble to when it actually went bang. Car starts right up, but if I try to get into ANY gear, I get nasty grind.
Old Jul 13, 2012 | 05:23 AM
jmd's Avatar
jmd
On level ground, car off, put it in 1st.
Start it up.
If it moves with the pedal down, fix that. The trans. will work a lot better.
The hydraulics may have a leak. Bellhousing bolts could have loosened. Could be time for a clutch. Pilot bearing could be junk. These are all guesses, but when all gears get worse at the same time, it's a good idea to check some external stuff.
Old Jul 13, 2012 | 07:46 AM
What you're describing is NOT a transmission problem; it's a clutch problem.
But since the T-56 clutch is different from the T-5 one, same advice applies. If money is an issue, DON'T use what you have of it, on the T-5; that only moves your long-term goal farther out of your grasp.
Old Jul 13, 2012 | 10:46 AM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
to be fair, I think a lot of us use these cars as our daily driver. I don't know if OP is in that situation, but if he is a year out from getting his T56, and only has this car, I say replace the clutch. A lot better than walking everywhere for a year lol. Just be SURE that you know it's the clutch. nothing worse than dropping good money on something and finding out you didn't diagnose it correctly.
Old Jul 13, 2012 | 11:12 AM
Were gonna tear down tomorrow and hopefully find the guilty party, replace it, and go from there....
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
