what torque converter
Old Jul 22, 2012 | 02:52 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
i got a lo3 305 tbi with ebl flash , lt1 cam , pro comp 1500-6500 rpm uintake manifold . a t 70 turbo set around 8-10 lbs of boost . 700r4 tranny with shift kit an corvette servo . 87 gm 10 bolt posi out of a iroc with 3.23 gears an disc breaks , an 27 " tires on back . i was gonna put a 2500 stall but then i i got to talking to a friend who thinks a 2000 rp stall will be better since i'm gonna daily drive it . alot of highway miles
any opinions ?
Old Jul 22, 2012 | 05:04 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: what torque converter
anybody ?
Old Jul 26, 2012 | 07:25 AM
Pro Built Automatics's Avatar
The stall will be based on what the duration of the camshaft at .050" lift? Lobe separation? And how you drive. Conservative? Moderate? Moderately aggressive? Or aggressive? And anything done to the motor. Let me know?
Old Jul 26, 2012 | 11:29 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
it's a l03 305 stock heads , either lt1 or lt4 cam ) ebl flash for tuning , procomp cyclone intake (1500-6500) t-70 turbo ,700r4 tranny , posi 10 bolt with 3.23 gears . my driving style is agressive . but i still use it most days , alot of highway driving to work . thats why i'm staying with the 700r4 . the cam , rear an turbo aren't in yet but the turbo goes in in aug . an the rear an the cam in sept- oct .
Old Jul 26, 2012 | 12:30 PM
I would go with a 9.5" lockup with a 2,600 - 2,800 rpm stall. This will allow the turbo to spool up quicker.
Old Jul 26, 2012 | 12:44 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
do you all have a web sight ? i may need a tranny soon .lol
Old Jul 26, 2012 | 05:28 PM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
You should be fine with a 2200rpm-2600rpm stall. Ha ha yeah the stock 700r4 will need to be upgraded soon for the upgrades that you have planned. I got my transmission and converter from Bowtie Overdrives. I'm very happy with the way it worked out.
http://bowtieoverdrives.com/index.shtml
Have you dynoed your car before? I like it. You have a sleeper Camaro RS that you still can say is powered by the L03!
Old Jul 29, 2012 | 12:58 PM
Go to: www.700r4l60e.com
Old Jul 30, 2012 | 06:14 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
ok thanks
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
