83 CAMARO CANNOT SHIFT INTO GEAR OR COME OUT OF GEAR
Car: 1983 Chevy Camaro Z28
Engine: 305, 4 barrel carb.
wHEN THE ENGINE IS RUNNING I CANT SHIFT IN OR OUT OF GEAR. THE CLUTCH LINKAGE SEEMS TO BE IN WORKING ORDER BUT NOTHING HAPPENS WHEN I PRESS THE CLUTCH. WHEN THE CAR IS OFF IT OBVIOUSLY SHIFTS FINE NO STICKING OR SLAMMING IT INTO GEAR. WHAT COULD BE THE PROBLE?
Re: 83 CAMARO CANNOT SHIFT INTO GEAR OR COME OUT OF GEAR
Welcome to the forums.
Around here, we don't use this. Extremely rude, and hard to read, besides. Instead, we use the proper capitalization, as a courtesy to those we are asking for help.
But this being your first post, I'll overlook that temporarily.
Look at your clutch fork while a helper pushes the pedal. If it's moving more than ½" or so, then the Z-bar is OK. (those break ALOT so don't assume anything)
If the clutch fork is moving far enough, it could be the fork itself is broken, the ball stud has backed out, or the clutch is just .... fornicated.
Didn't realize it was rude. Didn't mean to offend you. I type in all caps at work. Thankyou for the suggestions. If the z-bar and fork are in working order then it could be the fork from the inside?
Yes; the fork breaks sometimes where the narrow part meets the wide part, near the throwout brg.
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
I'm not sure if these cars have a slave cylinder but if they do you might want to check that as well. I had a '94 Ranger and that went bad and when it did changing gears while stopped became a real challenge but when the engine wasn't running there was no problem. Problem is is that with a bad slave cylinder you can depress the clutch all the way (requires a lot of effort to do when this is bad) but it doesn't disengage the clutch 100% so mine was still grabbing the flywheel and would even move the truck on flat roads.
dhonda200
Aug 11, 2015 11:50 PM
