HELP 700R4 Tci lock-up wiring kit
Old Aug 8, 2012 | 04:23 PM
luckydog0_18's Avatar
Car: 1986 camaro iroc-z28
Ok I've spent a hour on here searching threads, and cant seem to find my answer.
So I have a 86 iroc-z28 it had a 305tpi I built a 355 carburetor engine. This has been going on for about 5 months with limited time. Now at one point in time I came to the conclusion that I need the TCI wiring kit http://www.summitracing.com/parts/TCI-376600/
But now that its time to install the kit I am left with this question:: Why do I need it, I'm at a complete lose for words. I bought the tv bracket for my carburetor.
Can someone shed some light on this for me please?? Thank you.
Old Aug 8, 2012 | 04:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: HELP 700R4 Tci lock-up wiring kit
The kit is to control the torque converter clutch.
Old Aug 8, 2012 | 04:34 PM
Thanks for the response Apeiron
Right I did remember that, so it defiantly is need then? I feel like a dumb*ss for not remembering. still plugging the transmission's wiring in,right? What part of the 305 controlled this that makes me need this? so for the question's I would just like to understand what is what.. And thank again.
Old Aug 8, 2012 | 04:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The ECM controlled it before you took out the fuel injection.
Old Aug 8, 2012 | 04:40 PM
ok so I install this. but then I also plug the wiring into the trans like it was before? and the lock up was controlled by the fuel injection ok so its starting to come back to me. thanks a million.
Old Aug 8, 2012 | 04:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That kit replaces the factory plug and harness that went to the transmission before.
Read here: https://www.thirdgen.org/forums/carb...c-control.html
Old Aug 8, 2012 | 04:49 PM
wow thank's,that is exactly what I was looking for. Its bookmarked now. thanks again.
camaro11j
Sep 19, 2018 08:49 AM
italiano67
Dec 11, 2016 09:21 AM
Thornburg
Aug 25, 2015 01:46 AM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
