loud bang when tranny changes gears
Old Aug 11, 2012 | 04:42 PM
bypass-21's Avatar
Car: 1984 Trans Am
Engine: 305 cui
so figured out that i am loosing a small quantity of tranny fluid in the transmission, so i haven't payed too much notich on that since i am pretty low on funds and its something that needs to be taken care of soon. but recently i have noticed that when the tranny changes gears that a very loud bang can be heard from the back of the car and it feels like its coming from the rear right wheel when i first got the car it it banged only after fist gear, now it feels like it does when ever it shifts from gear to gear
any one have any ideas?
thanks!
Old Aug 11, 2012 | 04:55 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Re: loud bang when tranny changes gears
Sounds like the transmission mount is torn.
Old Aug 11, 2012 | 07:44 PM
bypass-21's Avatar
Car: 1984 Trans Am
Engine: 305 cui
i never changed mounts of any kind, is it easy? or do i need to drop the transmission?
Old Aug 11, 2012 | 07:49 PM
BOTTLEDZ28's Avatar
Transmission: A4
it will take you longer to get under the car then it will to remove the few bolts holding the mount to the trans. You will need a small jack to lift the trans up off the transmission crossmember so you can get the mount out. it is sandwiched between the transmission and the crossmember.
Buy an Energy Suspension mount and be done with it. Dont lay under the car without a jackstand.
Old Aug 11, 2012 | 07:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
simple. Unbolt the mount from the crossmember (one bolt), jack up the trans, unbolt from trans (two bolts), replace mount, reverse procedure.
Old Aug 11, 2012 | 08:27 PM
bypass-21's Avatar
Car: 1984 Trans Am
Engine: 305 cui
Thanks everyone for the advice, hopefully this solves my problom
Old Aug 12, 2012 | 06:56 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/trannymount
The poly mount can be an issue:
https://www.thirdgen.org/forums/tran...ison-pics.html
And if your car is equipped with a secondary cross member:
https://www.thirdgen.org/forums/hist...ss-member.html
JamesC
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
crazynights
Aug 21, 2015 06:53 AM
