sequential shifter question
Car: 1992 camaro rs 25th anniversary
Engine: 305 TBI
ok a while back i watched a toyota supra in-car drag video and noticed that when he shifted he did not use a clutch and after doing some research i found out that it was a sequential shift system which allows you do up-shift or down-shift by simply pushing forward or backward on the shifter and i've been looking for one for my car and i havent found any discussions like this so my question is: do they make one for a 700r4?
if you know or have a website link that sells them please post them
btw if it is neccessary that you have to know my car specs i have a 25th anniversary edition 1992 camaro rs it has a 305 tbi engine, 700R4 transmission and is an automatic, thanks for reading
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: sequential shifter question
for an auto, its called a manual valve body. Not something to bother with on the street. You can get manual/auto valve bodies that allow to to manually shift, or put it in D and have auto shifting
for a manual trans, its a bit different and the trans has to be built specially for this purpose, its not a simple add on.
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Look up trans-go or B&M shift kits for a 700r4 trans. You can get them to shift harder and manual shift depending on what you want. Some say the Trans-go is better, but then that's what i use so Im a little biased i guess. And by the way, a harder shifting trans. is actually better for the trans. than a slipping smooth shifting one.
NBrehm
Aug 25, 2015 11:49 PM
