What rear gear with a t56?
Old Aug 18, 2012 | 03:23 PM
cobrakiller1989's Avatar
A few questions since I've done my t56 swap.
1. What gear ratio do you have?
2. What rpm in sixth gear at 70 mph
3. What rpm and mph do you cross the line in the quarter mile at?
I'm thinking of going with a 4.11 or 4.30 when I swap my nine inch in. Currently I have 3.73 and it's pretty lame.
Old Aug 18, 2012 | 03:31 PM
Re: What rear gear with a t56?
Btw this is a street/strip weekend car. So I don't care about drivability. Heavily built 383 on a 250 shot of nitrous
Old Aug 18, 2012 | 03:44 PM
87350IROC's Avatar
Car: 87' IROC
I don't get it. If you don't care about driveability, why do you care what the rpm is at 70mph.
All of this is VERY easily calculated.
http://www.wallaceracing.com/gear-speed.php
Old Aug 18, 2012 | 03:46 PM
I was just saying I don't care bc it's not my daily driver, but I do hit the highway sometimes cruising around. Currently sixth gear seems useless unless I wanna cruise 120 mph
Old Aug 18, 2012 | 03:47 PM
Thanks for the link
Old Aug 19, 2012 | 12:08 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've used a T56 with 3.70's and 4.11's and I don't get into 6th until around 80MPH........
Old Aug 19, 2012 | 12:14 PM
87350IROC's Avatar
Car: 87' IROC
I don't get it guys. Not sure whats up with your setups, but I am running a 0.5 ratio 6th gear T-56 with 3.27 rear gears and have no problem at all running 6 at as low as 65mph. With that said, I am in the process of changing to 3.73's.
BOTTLEDZ28's Avatar
Transmission: A4
I had 4.10s in my car with a T56 and I hated them. First gear is useless so I swapped them out for 3.73s and I am a lot happier.
Old Aug 19, 2012 | 12:33 PM
John in RI's Avatar
That's why I don't like auto's,........ Always trying to keep me @ 1500RPM ! 6th gear under 2000RPM and the tourqe simply doesn't exist; Like driving a T5 @ 30MPH in 5th........
A lot of guys prefer 3.73's; I Like the 3.70's- just like the 4.11's better. I'm used to driving a 95 LT1 T56 with skip shift so I'm pretty used to reving first gear higher than "normal".
Old Aug 19, 2012 | 04:26 PM
87350IROC's Avatar
Car: 87' IROC
Yup I get it. But nothing beats it on the highway with the cruise control on. It really quiets down the engine and better mileage. I still find the torque more than enough to maintain 65 on any hill.
Old Aug 20, 2012 | 08:14 PM
mikebondi's Avatar
Car: 91 Camaro RS
Engine: 6.0 lq9 ls bored to 408
Transmission: T56 6 speed
Axle/Gears: strange s60 4.10 with a spool
mine has a 4.10 rear gear with 28 inch tall tires. it runs at about 80 to 85 in 6th gear. anything less and 6th gear is useless. it is like 1900-2100 rpm at the 80-85 in 6th gear.
on the strip im getting really hurt. i go threw the trap at just a bit over 5000 rpm. i run a 12.8-13.00 at 106-109.
i either need a shorter tire or a taller gear. if i had it over again i would have done a 4.56.
i think im just going to turn on some nitrous and keep cruising in 5th gear on the highway lol
Old Aug 20, 2012 | 10:18 PM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
I used a 3.73 for a while when I was troubleshooting some noise in my 9". I literally felt like I lost 50rwhp going from the 4.11 to the 3.73.
4.11 or steeper all the way!
Old Aug 20, 2012 | 10:52 PM
thank you. two answers to the actual question. im definitely going with at least 4.10. my only fears are too many rpm at around 130 mph trap times. 7000rpm will be fine, but any more ill be shifting to fifth lol
Old Aug 22, 2012 | 12:47 PM
wheelie250's Avatar
Car: 91 Z28, yamaha vmax, and zuki vitar
Engine: TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi, soon 3.73
I had a forth gen LS T56 car with all the bolt ons, 17x11s and a 4.10. I LOVED IT!!! at 75-80 it was sitting at around 2200. on street tires I couldve leave the line at more than 2k without slipping the clutch something terrible. I wouldnt change a thing, I absolutely loved 4.10s on the street. Once the car was rolling it would hook well though.
Old Aug 22, 2012 | 12:50 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I have 3.70s and its around 1800 RPMs at 70+ mph.
The problem with 4.10s is that the gear teeth are so small for the stock 10-bolt that theyre very weak, especially considering its a manual trans and it will see severe shock loads. You could make 4.56's work easy as far as the gear ratios themselves go, but just remember 5th and 6th gear are not meant to be driven under load/acceleration. They werent built to be strong enough for that, so there is a point where going higher doesnt get you anywhere, but its a long way from 3.73s and 4.10s.
If I had a 9 inch I'd go 4.56's probably.
Old Aug 23, 2012 | 02:47 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Same for me. I tried a 3.27 rear and it felt much slower. 3.70 is the lowest I'd want and whenever I upgrade to a 9"/s60 I'll probably opt for 4.10.
Old Aug 23, 2012 | 03:09 PM
mikebondi's Avatar
Car: 91 Camaro RS
Keep your cam in mind to. Mine doesn't work real well below 2k with the low 6th gear. So if you go with a big cam 1700 rpm wont work to well.
Old Aug 23, 2012 | 11:26 PM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
I have a t56 with the .5 ratio and 3.23 gears. I can shift to 6th at like 60. I also routinely shift to a gear to cruise at under 2000 rpm if possible. Love the low end torque of a 350.
jharrison5
Aug 19, 2015 05:53 PM
AkDrifted
Aug 17, 2015 07:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
