TH350 fluid flow?
Old Sep 2, 2012 | 09:04 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
TH350 fluid flow?
Could someone tell me please which way does the fluid flow in the cooling lines of the TH350. Is the top connection on the side of the transmission for the cooling lines flowing to or from the transmission? Thank you.
Old Sep 2, 2012 | 09:39 AM
ddrury14's Avatar
Car: 87 iroc z
Engine: 5.7 tpi
Transmission: 350 turbo
Axle/Gears: stock for now
Re: TH350 fluid flow?
im pretty sure that your upper is your return to the tranny or atleast is my theory because of gravitys natural flow.
Old Sep 2, 2012 | 11:30 AM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Well with that theory wouldnt it be the bottom line then?
Old Sep 2, 2012 | 11:33 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Fluid flow is against gravity to prevent aeration.
Old Sep 2, 2012 | 11:35 AM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Oh got ya, and ddrury is right upper return/lower feed cooler
Old Sep 2, 2012 | 04:11 PM
ddrury14's Avatar
Car: 87 iroc z
Engine: 5.7 tpi
well since a couple of yall i see have done this th350 swap. i think ive gotten all my questions answered in other threads. except one thing, does the computer have berring on the 700r4 as far as the lock up? if it does how will this affect the new th350.? would appreciate an answer from someone that has succesfully done this swap and is done with it i guess. oh and i have a tpi setup, dont know if it makes the difference? thanks
Old Sep 2, 2012 | 05:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The computer wouldn't know or care if you replaced the 700R4 with a TH350.
Old Sep 2, 2012 | 06:01 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Old Sep 2, 2012 | 06:54 PM
ddrury14's Avatar
Car: 87 iroc z
Engine: 5.7 tpi
thats kinda what i was thinking since its a mechanical action and fluid. but i have a couple guys tellin me that it wont function properly if the vss inside the trans is different from the 700r4.
Old Sep 2, 2012 | 07:14 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
I wouldnt listen to them guys anymore, theirs not a single electric wire to hook up to the th350, make sure you hook up the kickdown cable and a vacuum line to the th350. Your engine wont know the difference.
Old Sep 2, 2012 | 07:39 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
No need for a kickdown on a TH350. Kickdown and TV cable are two different things.
Pac J
May 17, 2020 10:44 AM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
