TH350/Cooler Plumbing?
Old Sep 2, 2012 | 07:40 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
I understand top line on the trans is return and bottom is feed but I am interested in running to an aftermarket cooler (vertical feed/return port; imagine top is return and bottom is feed). What if I want to tie into the radiator's trans cooler as well? Is it worth while or not?
Double checking, top trans line to top cooler line, correct?
Old Sep 2, 2012 | 08:48 PM
88gunmetalgta's Avatar
Re: TH350/Cooler Plumbing?
I'm getting ready to put my cooler in too.
I found a thread on hotrodders that said it goes from the top rad line, to the bottom of the cooler, and then from the top of the cooler to the trans return line. Makes sense because the fluid flows from bottom to top in the radiator to begin with.
Old Sep 2, 2012 | 11:32 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
thanks kinda thought that but wanted to make sure. Think it's necessary to run it to the radiator cooler then to a aftermarket cooler with a 2,200-2,400 stall or just strait from trans to aftermarket cooler?
Old Sep 3, 2012 | 05:06 AM
That depends on your combo, and what Trans cooler you have, but in most cases the factory cooler should be used too.
ZZ3Astro
Aug 13, 2019 12:57 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Dialed_In
Aug 20, 2015 01:45 PM
silentneko
Feb 1, 2002 09:07 AM
Chris Sartori
Sep 24, 2001 08:39 PM
