Looking for advice for my setup
Old Sep 8, 2012 | 05:01 PM
Sidethumper's Avatar
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
So I have the rear end out and am wondering what to do next., I have 2.73 gear open diff 10 bolt right now with drums. I am planning on putting in a old school 350 carbed beefed up and am thinking of going with a manual trans. Havent decided witch one yet though. The car is basically going to be for show... no dragstrips but I would like it to take off well if I want it to. What gear change (If any) should I make? I also want to make it a posi with disc brakes. I have been searching for the gears and parts etc to make this happen but have not found exactly what I need . Any advice would be appreciated and maybe some part numbers or a good website where I can purchase some parts.
Then I also have a guy near me that has a 10 bolt posi disc brakeswith 3.27 or something close to that and he wants $350 for it..... would that be a better way to go or just build mine up?
Old Sep 9, 2012 | 08:47 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Looking for advice for my setup
I'm giving you some advice I give a lot, and it fits your situation at least as well as most others: Go to your local salvage yard and spend $100 on a complete rear axle assembly from a '91-'92 V6 / auto. That'll give you the 7.625" 3.42:1 gears, and the 28-spline axles. Then install a Lock-Right. http://www.summitracing.com/parts/PWT-1931-LR/
Old Sep 9, 2012 | 07:46 PM
I will try and find one, I dont think I will get one for 100 bucks though. I live in Michigan and people charge a ton of money for stuff. Thanks for the advice I like that gear ratio kind of an in between. Seems like the Lock Right is an easy install also but rather pricy. That rear end also has the disc brakes?
Bubbajones_ya
Jul 6, 2024 08:32 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
customblackbird
Oct 1, 2015 04:30 PM
R13_Braz
Sep 18, 2015 05:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
