700r to wc swap
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: 700r to wc swap
You will need the pedals etc. Are they both V6 or both V8? If so fairly straight forward but I can not say about the speedo. For the wiring look to the bottom of the T56 swap page 3 for some of the info. He covers the auto to manual wiring plus part of your back up light wiring. Worth the reading especially with the pics.
Re: 700r to wc swap
Thank you for your response. I have started disassembly of the donor car and it looks pretty straight forward. Will I have to cut openings for the clutch and shifter holes or are there knockouts? Any tips for unbolting the bellhousing? Thanks again.
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: 700r to wc swap
Make sure to have the torque arm bracket bolted up on the trans already i had this problem yesterday also make your cut in the floor from under the car so u dont run into setting the interior on fire due to the sparks from a cut off wheel also when installing the pedals remove the steering column makes it alot easier to see while under there
Re: 700r to wc swap
Thanks Soarestransam but I didn't understand about the torque arm being bolted up. I read about your trouble with alining the pilot bearing and the flywheel, did you resolve that issue?
Re: 700r to wc swap
The holes for the clutch master may be recessed or marked but they are not knockouts and not all cars had them marked. Do not trust the holes in the padding to be in the proper location. Put the pedals in, mark locations of everything, pull then out and drill and cut your holes. The shifter hole seems to be the recessed area under my console but I would only cut what I needed plus a little.
I haven't done it yet but it is my understanding that the torque arm bracket needs to be put on first because the top bolt is very hard to get to when everything is in place.
Re: 700r to wc swap
[quote=redvalz28;
p.s. do you have pics of your 68 bird?[/quote]
I will get some and let you know where they are posted. Hopefully this weekend.
84z96L31vortec
Aug 20, 2017 12:16 AM
Hello, Michael
Aug 20, 2015 03:19 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
