t5 swap.. help
Old Sep 13, 2012 | 05:23 PM
camaro211z28's Avatar
Car: 92 camaro RS
Engine: vortec 350/396
t5 swap.. help
i did a t5 swap in my 91 camaro. everything is working fine except the hydraulics. i got the master and slave out of a 3.4 camaro. i bled the **** out of it and it still grinds in reverse and it does not shift easy at all. u have to cramp it in to gear but it does not grind going into any gears except reverse. any ideas? r the hydraulics different from a v6 t5 and a v8 t5? the part numbers r different on autozones website
Old Sep 14, 2012 | 04:32 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: t5 swap.. help
For reverse you may need to put it in a forward gear first then into reverse to prevent grinding. This is somewhat normal. Hopefully someone else has ideas for the rest.
The part #s are different due to different bore sizes of each component. They should work though.
Old Sep 15, 2012 | 09:28 AM
Re: t5 swap.. help
2QUIK4U
Jul 16, 2015 02:18 PM
marcus88
Feb 3, 2015 07:27 AM
xdamxincx
May 28, 2006 01:18 AM
Thirim
Mar 18, 2005 06:49 PM
