What are these brackets for? PIC
Old Sep 16, 2012 | 05:27 PM
Sidethumper's Avatar
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
I just bought a rear end out of a 92 z28 It has posi and disc brakes, was wondering what these brackets were for? Im thinking the E brake cables go through them maybe?
Old Sep 16, 2012 | 05:30 PM
Re: What are these brackets for? PIC
These cars have no "E" brake that I know of; only the "service" brakes (the ones that stop the car when you push the pedal), and a "parking" brake.
Those are for the parking brake cables.
Old Sep 16, 2012 | 05:38 PM
Parking brake? who needs that? So its not an emergency brake ? Hell if they are not going to help you stop in an emercency then why bother?
Old Sep 16, 2012 | 06:25 PM
Matter of opinion I suppose...
Just try stopping your car with the rear brakes only, with just that wimpy cable actuating them without power assist, in any kind of "emergency". Ain't happenin.
All that thing is good for, is parking. Isn't worth a steaming bucket of ... spit ... in an "emergency".
Take it or leave it. It is what is it. (and isn't what it isn't)
Old Sep 16, 2012 | 06:40 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
It was called a "emergency" brake b4 the hydraulic brakes became cool and it was put in place to please the powers that be.. The cars weren't as fast, heavy or powerful back then sooo a E brake could help stop ya in a panic situation.
Its either a P or E brake in my world, if your stopped and have a manual trans its a P-brake. If your brakes fail for some reason then the P becomes a E-brake. Will it stop you like the normal brakes will? Nope, but it will slow you down better than flinstone brakes ever will..
Old Sep 16, 2012 | 06:45 PM
Originally Posted by TTOP350
It was called a "emergency" brake when the hydrolic brakes became cool and it was put in place to please the powers that be.. The cars weren't as fast, heavy or powerful back then sooo a E brake could help stop ya in a panic situation.
I would like to get the P brake working I suppose, I want to put in a manual trans and it would be helpful. Im kinda at a point in my build though that Im thinking of just putting the auto back in sheesh. Ive done so much to it already its starting to drain my pocket and my nerves.
Old Sep 16, 2012 | 06:46 PM
Really??
Try a "panic" stop from the rip-roaring speed of, say, 10 mph. Measure the stopping distance. I think you'll agree once you try it under less than "emergency" circumstances, that if you REALLY get into some kind of "emergency", you're better off driving it into the ditch beside the road, rather than counting on THAT thing to actually do anything useful.
Old Sep 16, 2012 | 09:21 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Heh after new rotors and pads (J65), recall pistons, cable adjustment etc etc, I managed to get mine to work as a parking brake. So long as the car is not parked on a heavy slope of any kind, like my driveway. If relying on this alone (ie not in Park), it will sit happily for a period. Then it might decide to go for a little excursion into the middle of the road when my back is turned
Over here we use the term 'handbrake'. Covers all options.
Old Sep 17, 2012 | 04:17 PM
So should I or do I need to put some kind of poll out there?
Check this box if you think I should bother putting it back in
Check this box if I should delete the "handbrake" altogether
If it is not going to help in any way then **** on it I will juat delete it... Ive got enough *** raping going on with this rear end of mine lol. Now the guy says ohh sounds like the pinion bearing might be bad too thats another 400 . Jesus Christmas.
Old Sep 17, 2012 | 07:52 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
I use mine all the time. I don't rely on it 100% but if I'm on a somewhat flat surface and need to jump out quick the brake will hold the car. Mine does hold pretty well on an incline but I never fully trust it so I shut the car off and leave it in gear. Mine is a manual so I feel it is a necessity. On an auto not so much, but even on my auto cars I use the brake as to not overload the parking pin.
Old Sep 17, 2012 | 08:06 PM
TTOP350's Avatar
Really??
Its def NOT going to leave retina sized divits in the windshield.... It'll help slow ya down till they melt off....
Old Sep 17, 2012 | 09:37 PM
Definitely hook it up and make it work.
Just be realistic about what it's good for.
Old Sep 18, 2012 | 11:34 AM
Thanks for the advice.
Old Sep 20, 2012 | 09:21 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Ok,bypassing the whole "hand brake" debate (thanks Treefiddy), I think those were fabbed up by someone. The 91 setup I have had the usual guides on the body and trailing arms. Never seen guides on the diff cover. Looks like they would hook on debris maybe.
Old Sep 20, 2012 | 09:50 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Heh, we got foot-brakes too
Think the one on the left already did.
Old Sep 20, 2012 | 04:41 PM
Yea I have mounting brackets on the chasis were the old drum brake handbrake cables went. I should be able to use them eh? I really dont like them on my diff cover like that. Looks stupid. Well... should be getting my Diff back tomorrow 6 Benjamins later. A complete overhaul. For that price it better be like new. Then comes the task of learning how to put in a rear disc brake system.
Old Sep 20, 2012 | 08:46 PM
TTOP350's Avatar
Those brackets are for a 93 and up too ?? 4th gen disc rear.
I have never seen them on a 3rd gen and I have several 91-92s with factory disc rears. That doesn't mean GM didn't put them on some 3rd gens. The factory diff cover for those brackets are a bit different to clear the brackets.
I'm wondering if the rear pictured is from a 4th gen.
Old Sep 21, 2012 | 06:31 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here are the guides on a thirdgen:
https://www.thirdgen.org/forums/atta...-89-guides.jpg
JamesC
Old Sep 21, 2012 | 09:46 AM
TTOP350's Avatar
Could you measure the width of the rearend from axle flange face to axle flange face?
Old Sep 21, 2012 | 09:56 AM
TTOP350's Avatar
JamesC
Thats a drum brake housing and shouldn't have those bolt on brackets from the factory. Drum brake housings (like the one pictured) have the large clip on the top driver side. Its for the drum E/P brake cables.
My guess is someone bought a 4th gen rear for the brakes and put it all on a older rearend..
The factory diff cover has notches or cutouts on the outer edge for clearance when using the wire bracket..
The OP or the pic in the link have the wire brackets on the wrong side. I "think" the OPs are correct, not 100% sure tho.
Old Sep 21, 2012 | 10:33 AM
JamesC's Avatar
I purchased the fourthgen guides a few years ago, P/N 10285819 R and 10285818 L. Pic below seems to verify orientation (post #6):
https://www.thirdgen.org/forums/brak...e-mod-4th.html
JamesC
Old Sep 21, 2012 | 11:10 AM
TTOP350's Avatar
JamesC
10-4 It has been awhile since I have had a factory one in my sites.. I looked real quick for them on a parts site and didnt see them..
Old Sep 21, 2012 | 12:41 PM
Ok so you guys are confusing me here.... Drum brake housing? I have disc brakes on the rear pictured. And are my guides correct or not? I would actually like to get new ones like in the link with the summit cover on it. Are those the ones I need and if so where do I get them? Also thanks for the other link that shows the new P brake cable being installed... I have to do all of that to mine once I get the rear end back and Im not sure what brakes or extra parts I need.
Old Sep 21, 2012 | 12:51 PM
TTOP350's Avatar
In the link JamesC posted up, the rearend is a drum brake housing.
Yours is disc.
I'm just wondering how wide yours is because I'm thinking it may be a 93-up rearend.
Old Sep 21, 2012 | 12:54 PM
JamesC's Avatar
J65, TTOP. I converted the rear from the Delco-Moraine system to PBR's.
JamesC
Old Sep 21, 2012 | 12:57 PM
Yours is disc.
Its at the shop getting new seals and bearings, I am suppose to get it back today at 3pm I will measure it and let you know. It is out of a 92 z28 or at least thats what I was told.
Old Sep 21, 2012 | 01:01 PM
JamesC's Avatar
BTW, Side,
I purchased the guides from the dealership using the part numbers that I provide above.
JamesC
Old Sep 21, 2012 | 01:08 PM
BTW, Side,
JamesC
Are those the guides I should have? Those are 4rth gen. Oh well guess I will figure it all out once the rear gets put in.
Old Sep 21, 2012 | 01:45 PM
JamesC's Avatar
If you're converting from drum to discs, the following FAQ discusses conversion, cables, combination valve and so on:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Sep 21, 2012 | 02:01 PM
TTOP350's Avatar
JamesC
I keep forgeting the old iron disc had those clips also.
Old Sep 22, 2012 | 07:45 PM
JamesC
Thanks James, I just got the new rear in the car today. Looks pretty good I think. I still have to touch up two spots with paint and get the hardware for the sway bar. Then get the new calipers and P brake cables from ED and the combo valve as well.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
gt4373
Sep 9, 2015 10:29 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
