whining sound when coasting
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
I recently swapped a 4th gen rear end into my 84 Z28. I have noticed a whining or humming when I am coasting above about 30 mph. The sound is not present under acceleration or at low neighborhood speeds. I thought it was the axle bearings, so I changed them. But, the sound is still there. Could it have something to do with the crush sleve? What else could it be?
Car: 1984 Z28 T-TOP
Re: whining sound when coasting
I did have a small leak coming from the middle of the yoke around the nut.
Car: 1984 Z28 T-TOP
And the drive shaft is the same. I didn't have the noise prior to the rear end swap.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Did you pull the cover off the differential cover and look. See if there is metal flakes in the oil.
Car: 1984 Z28 T-TOP
yes and they looked great. I replaced the gasket and fluid with Royal Purple. So significant shavings and the teeth looked fine.
Engine: 454-350
Is this differential a posi? if so you need to use the posi additive with your oil.
Car: 1984 Z28 T-TOP
yes it is a posi, but you don't need additive w/Royal Purple. A few weeks ago I had some conventional gear oil and some posi additive and it still made the noise. Could the crush sleeve on the pinion be an issue? again, the leak comes from the pinion nut area and I already changed the front seal. When I took off the yoke I did not change the crush sleeve. i just market the nut and yoke and put it back to the same spot.
Car: `86 SS / `87 SS
Gear pattern may not have been set up correctly. There is a drive pattern where the pinion to ring gear teeth touch under power and there is a coast pattern under coasting.
Engine: 454-350
It might be your pre-load on the pinion, did you follow the recommended procedure for removing and installing your yoke.
Car: 1984 Z28 T-TOP
Nope, how do you set the pre-load? Can you do it with the rear end still on the car?
Engine: 454-350
Well the procedure starts when you remove the yoke nut to start with. We must of missed that step. How tight did you crank the yoke nut down.
Car: 1984 Z28 T-TOP
just back to the origional line. I marked it prior to taking it off.
Car: 1984 Z28 T-TOP
I only removed the nut and the yoke during the seal change. i don't think I messed with the pre-load during the seal change. Can I fix by just replacing the crush sleve?
Engine: 454-350
If you tightened to the original mark you should have the correct pre-load.
Engine: 454-350
I don't know for sure without being there. Could the pinion bearing be worn out? How many miles on the donor car?
Car: 1984 Z28 T-TOP
is there a way to check the pinion bearing while on the car? or do I have to take out the differential to check it?
Engine: 4++,350 & 305 CIs
A factory service manual would help you. If you don't mind reading.
