Broke the ring gear on my 9 bolt
Old Sep 22, 2012 | 01:20 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I've swapped rear ends before but never really taken one apart. I broke a tooth on my ring gear, its a stock 9 bolt with 4.11 gear set. Any advice on if I should try to fix it or just buy an aftermarket rear? I'm probably pushing 400HP to the wheels with 315 drag radials so there is a fair bit of stress on the rear.
Old Sep 24, 2012 | 10:02 AM
big gear head's Avatar
Re: Broke the ring gear on my 9 bolt
A 12 bolt would hold up much better. I'd say that you are at or just above the limit for what that rear end can handle. A 12 bolt isn't cheap, but neither is replacing gears all the time.
hectre13
Dec 11, 2023 08:14 AM
Mickeyruder
Sep 2, 2015 02:45 PM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
