tranny wont shift please read on.
Old Oct 3, 2012 | 10:57 PM
Graphite07's Avatar
this morning the 1990 RS camaro ran fine. left work today the engine rev very high and top speed was 20MPH! now if i punch it the car would get up to 40 MPH put will not shift back to Over drive. tranny fluild looks ok and not low. but funny thing is, when i start my camaro it idles at 1000 rpm's or 1100 or 1200 rpms. now when i start the car up it idles at 2000 rpms. never done this before and today it just started when the tranny would not shift in to over drive like it stays in low gear.
Old Oct 3, 2012 | 11:54 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: tranny wont shift please read on.
Originally Posted by Graphite07
tranny would not shift into over drive
Doesn't shift up to any gear (2nd /3rd ) or only won't shift into O/d ?
Completely different situations
Old Oct 4, 2012 | 05:29 AM
Graphite07's Avatar
like it is stuck in 1st gear.
Old Oct 4, 2012 | 07:48 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Presuming your TV cable is adjusted correctly?
http://sethirdgen.org/tvcable.htm
the governor that controls shifts may be bad ; the plastic teeth that drive it may be worn / broken or governor is stuck
Governor is under the round metal cover on drv side rear of trans
See post # 7
http://www.corvetteguruforum.com/mod...forumpost99605
Old Oct 4, 2012 | 04:01 PM
Graphite07's Avatar
i guess the cables popped off the throttle body housing...any ony have a picture how they hook back up? lower cable on a big flat thing with a slot in it and a smaller cable with a green piece of plastic on it.the plastic green piece that holds it on the throttle level that plastic broke.
Old Oct 4, 2012 | 05:29 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Crank the throttle body open.
The one that does the pulling is the throttle.
The one that is pulled is the TV cable, mandatory for proper trans. shifting.
Old Oct 4, 2012 | 06:35 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Did you LOOK at the pics in the TV cable link I posted for you above ??????
Shows exactly where the cables (inc cruise if fitted ) go
camaro11j
Sep 19, 2018 08:49 AM
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
crazynights
Aug 21, 2015 06:53 AM
tnrednneck
Aug 13, 2015 08:57 AM
