Hit a major problem
Old Oct 19, 2012 | 02:23 PM
86F.BiRD's Avatar
Car: 1986 Pontiac Firebird Base
Engine: SBC 350
Transmission: Borg Warner T-5 World Class
Axle/Gears: 4th Gen Rear with 3.73s
Hit a major problem
I have a 14 spline output shaft on my Borg Warner t5 and I need a 10 1/2 inch clutch. Need help from anyone who has run into this problem before!
Old Oct 19, 2012 | 03:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Hit a major problem
Astro van clutch I believe. And I assume you already know its a v6 t5 and with such a low first gear its not the best choice for a v8 application.
Old Oct 19, 2012 | 06:13 PM
86F.BiRD's Avatar
Engine: SBC 350
I figured out that it was for a v6 but I found a 10.5 inch 14 spline on speedway
Old Oct 29, 2012 | 09:56 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Astro van clutch disc is the common solution to the problem as //<86TA>\\ mentioned.
db057
Sep 4, 2015 07:57 AM
someone972
Aug 30, 2015 12:52 AM
zeitghaist
Aug 18, 2015 07:33 AM
92camaroJoe
Aug 13, 2015 06:07 AM
hokis
Aug 9, 2015 03:57 PM
