drive shaft rubbing loop
Old Oct 26, 2012 | 06:28 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I just installed a UMI adjustable torque arm with X member/DS loop. Under normal cruise its all quite. From the dig or very slow roll into WOT I get a vibration and rubbing noise under the center console area. I looked under the car and it appears the front yoke is rubbing inside the front bottom/drivers side of the drive shaft loop. I'm guessing it shifts under heavy load because its about 1/4-3/8" away under no load. The wear mark is about 1/8" and i can see it on both the loop and drive shaft yoke. It's a 3" LS1 DS, sure it wouldn't hit if it was stock size DS.
So my plan is to just grind/trim like an 1/8" off the DS yoke with a dremel. I know the DS is balanced but I'm just going to give it a little shave.. Anyone have a better idea?
Old Oct 26, 2012 | 08:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: drive shaft rubbing loop
If your LCA are adjustable, shorten them a little bit. This will move your driveshaft forward slightly and may be enough for the yoke to clear the loop.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
Ozz1967
Aug 16, 2015 10:23 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
